02-25-2020 05:34
02-25-2020 05:34
Hello - I wanted to add Elliptical to my exercise shortcuts so I went into the app, and into exercises where you can move the different exercises up and down. Elliptical is not one of the options, so someone on a board said to click the + and add it then move it up to one of the first 6. However, I do not have a + and it says "All shortcuts in use" ... does the Inspire HR not have Elliptical exercise capability, or is there a workaround so I can add it?
Best Answer02-25-2020 08:38
02-25-2020 08:38
When it show 'all shortcuts in use', you have to delete one or more of them before it will show all the other choices you can add.
See Can I reorder the exercise shortcuts on my Fitbit device? , though I don't think that help section tells you about deleting one if shortcuts are all used.
