09-16-2023
15:06
05:58
ManuFitbit
09-16-2023
15:06
05:58
ManuFitbit
My Fitbit inspire is not changing. It show check charger message, but charger is perfectly fine. Very irritating with it.
Moderator edit: clarified subject
09-18-2023 12:52
09-18-2023 12:52
It's a pleasure to have a new face here @Amankumar52. Thanks for confirming
Thank you for informing me that the charging cord is not the problem.
Please attempt the following actions to resolve the problem:
As a first step, I'd want to use a toothbrush and some water to clean the charging connections on the back of the device.
I also need you to clean the pins on the charging wire with a cotton swab and some disinfecting alcohol, ensuring sure that no swab fragments remain on the pins.
Finally, connect it to another USB port or a UL-certified USB wall charger.
