09-24-2024 18:30
09-24-2024 18:30
I used to be able to manually add spin and now it goes through all the motions but doesn't actually add it. I've tried adding it in every place possible and it does not work.
Best Answer09-25-2024 10:11
09-25-2024 10:11
Hi @k.isthebest the Ionic is under a voluntary recall, so there is no support to help you with this. Why not check into the recall as it reimburses you for the device. click to learn more
Best Answer09-27-2024 09:40
09-27-2024 09:40
Welcome to the Fitbit Community, @k.isthebest. I'm sorry to hear that you haven't been able to add exercise manually to your account.
If you have a Fitbit Ionic, it's under recall as @Odyssey13 mentioned. If you have a different device, please let us know in order to move your post to the correct board and give you the proper assistance.
09-27-2024 16:46
09-27-2024 16:46
Best Answer10-01-2024 12:50
10-01-2024 12:50
Thanks for getting back to us and for the clarification @k.isthebest. I moved your post to the Other Inspire trackers board and will be glad to assist with your exercise query.
Could you please confirm that you're following these steps in order to log your exercise manually:
