11-18-2024
01:53
07:34
ManuFitbit
11-18-2024
01:53
07:34
ManuFitbit
I bought a secondhand Fitbit Inspire 2. I reseted it and cleared the data and now the only screen showing up is downloading the app. I downloaded it and it still doesn't recognise. I looked around and it said to delete the current Versa 2 account, however I have no way of contacting my seller. Is there any other way to fully reset it?
Moderator edit: clarified subject.
11-19-2024 07:17
11-19-2024 07:17
Welcome to the forums @Brainobrien.
Thank you for providing the details reagarding your Inspire 2.
Have you been using another device connected to your Bluetooth? have you unpaired it by any chance? I'd suggest doing the following:
If you can't get started with your Fitbit device, usually a missing requirement is the cause. Carefully review the requirements provided in the help article Why can't I set up my Fitbit device?
