05-01-2020
18:46
13:07
RicardoFitbit
05-01-2020
18:46
13:07
RicardoFitbit
Suddenly iPad has stopped syncing last evening. Have tried all the suggestions to no avail including an agent. I have it installed with MyFitnessPal program on my iPad as well as my laptop. For years I must sync on my laptop and then I can sync on my laptop. If I uninstall the Fitbit will it lose the data already stored there or what other options are there?
05-15-2020 07:23
05-15-2020 07:23
I have the same issue. Since I update phone it will not synch. Help!
05-15-2020 07:26
05-15-2020 07:26
Same experience with it saying it is trying to synch with an Apple Watch
08-13-2020 14:17
08-13-2020 14:17
Did you ever resolve your connection isdues? Mine is connected, but I've tried EVERYTHING I could find and nothing fixes that mine has the incorrect time.
It has the date correct. But nothing fixes the time. Believe me I've researched and tried every suggestion. Thanks, Tanya
08-13-2020 14:20
08-13-2020 14:20
Same issue. All seem to be connected except the time. I searched and tried every step suggested. I can't get it to sync the correct time. Frustrated! I also have Inspire HR
Thanks, Tanya
08-13-2020 14:23
08-13-2020 14:23
My issue is the time. I've tried every suggestion and nothing works.
Thanks
08-13-2020 14:30
08-13-2020 14:30
The correct time was never an issue for me. I just couldn't get it to sync with my phone. Turned out to be user error on my part. My kids bought me the Fitbit. I thought I had the Inspire. Turns out I had the Inspire HR. Once I figured that out, everything worked fine. Sorry I can't be more help.
08-13-2020 14:32
08-13-2020 14:32
08-13-2020
16:44
13:51
RicardoFitbit
08-13-2020
16:44
13:51
RicardoFitbit
My Inspire HR won't sync with the latest update
Get Outlook for iOS
Moderator Edit: Formatting
08-13-2020 16:47
08-13-2020 16:47
Have you solved the issue? I cannot.
08-13-2020 18:42
08-13-2020 18:42
08-13-2020 19:21
08-13-2020 19:21
08-14-2020 10:53
08-14-2020 10:53
Thank you, as soon as I turned the bluetooth off on my android phone, it worked!
08-14-2020
14:31
16:00
RicardoFitbit
08-14-2020
14:31
16:00
RicardoFitbit
Honestly, it is probably an iPhone update. What I do is "unfriend" my
Inspire HR in settings -> bluetooth. Just remove it and it will reappear
under other devices on the bottom, so I do that regularly to resync. O/w I
have no idea.
Very Respectfully,
*Cynthia*
Cynthia
Moderator Edit: Personal info removed
08-14-2020 15:35
08-14-2020 15:35
08-14-2020 18:00
08-14-2020 18:00
08-15-2020 02:12
08-15-2020 02:12
08-15-2020 06:21
08-15-2020 06:21
08-15-2020 19:13
08-15-2020 19:13
08-15-2020 21:43
08-15-2020 21:43
08-16-2020 17:23
08-16-2020 17:23
