09-03-2019
11:02
17:03
AndreaFitbit
09-03-2019
11:02
17:03
AndreaFitbit
I gave up my friendly little Flex2 for a new Inspire. I might be sorry now that I did. I am a grown woman with no major infirmaries, but I absolutely cannot put the device on my own wrist. The little peg does not want to go into the hole. Even my husband has trouble helping me. What are my alternaitves?
09-03-2019 11:06
09-03-2019 11:06
Hi @mrsthread Try applying a small amount of Vaseline or something similar and you should be able to get the peg into the hole. It will get easier over time.
I hope this helps!
Best Answer09-03-2019 11:06
09-03-2019 11:06
I hope this helps!
Best Answer09-03-2019 16:03
09-03-2019 16:03
Best Answer10-25-2021 12:00
10-25-2021 12:00
I got an inspire after my fitbit one died for the last time, I really like it after continually wear the band came part at one of the pins, tried and tried to get it to stay together but it wouldn't. I thought I lost it at work, but didn't I ordered a new band off Fitbit site and it came fast, I put it together and the new bands pins won't hold every time I moved my wrist it fall apart again so I got mad and gorilla glued it together at the pin left it for 8 hours.Now Im been wearing it for 2 days and it s Great.
10-26-2021 17:07
10-26-2021 17:07
Welcome to the Fitbit Community @lorimiddleton59. Thank you for sharing the steps you have followed in order to wear your Inspire band.
This could help other users.
Keep on visiting the forums.
