10-27-2021
16:12
23:01
10-27-2021
16:12
23:01
Thanks for stopping by the Inspire 2 forum! Learn all you need to know about Inspire 2 by checking out the manual.
Having trouble? Check out our top troubleshooting tips.
Pro tip: If you wear your tracker on your wrist, make sure it's set to On Wrist mode to track all your stats.
Quick tips! Check out our helpful tips for getting the most out of Inspire 2, including:
02-07-2023 17:05
02-07-2023 17:05
Thank you! I’ve been having major problems with my inspire 2 skipping as many as 3 to 4 nights of my sleeping, despite having it charged enough, set to the right settings for being on my wrist, and being tight enough on my wrist. It will work great for as many as four days and then all of a sudden three days later, I’ll go back and check and it hasn’t done anything for three days. I tried closing the app re-opening the app first quitting the app re-opening the app it does absolutely nothing. Also, I’ve noticed that sometimes when I go in to check my sleep history it won’t show a day or two and then while I’m just looking at the app, maybe a couple minutes later, it’ll suddenly refresh and there’s all my data. So I don’t really know what’s going on but I’ve had this now for about two months and it literally has worked only about 45 to 50% of the time. I’ve posted my problems, on other sections of this health community and first we thought it was my battery wasn’t charged enough (and I did have it at a very low battery at that time) but fully charging my battery and it worked for about four days and then three days in a row it recorded nothing. And that’s the most recent experience. I haven’t had it record anything since this last Friday and and it’s now, Tuesday. So I am hoping that this manual will help me see what I’m doing wrong.
Thank you. PS
PS: do you have a direct link to the actual forum for the inspire two? Because when I look in the selections w the pictures of the watches, there’s only an inspire three. Again, thank you.
02-07-2023 17:46
02-07-2023 17:46
Hi @jbdean you posted in the right forum area. There is no dedicated Inspire 2 forum.
Support for Inspire 2, Inspire HR, and Inspire trackers
02-22-2023 17:07
02-22-2023 17:07
My Fitbit inspire 2 is glitching. The screen won't turn off and it randomly swipes between different screens. It barely responds when I tap the screen or use the buttons. It also randomly selects and unselects options. I treat is well and I don't know what caused it to happen. I tried restarting it a few times. I plugged it into power and it showed a smiley face. Then I was able to clear the user data. After reconnecting it to the app, it was still glitching. It is just past it's one year warranty so I can not return it. Has this happened to anyone else? Please help me out. Thanks.
Best Answer03-11-2023 03:18
03-11-2023 03:18
I'm having the same problem
Best Answer03-17-2023 14:16
03-17-2023 14:16
My Fitbit has locked - can’t remember how to reset it
Best Answer05-31-2023 06:53
05-31-2023 06:53
Thank you so much for this help. I thought I broke my Fitbit. Grown to love it!
18:04
10:08
ManuFitbit
07-12-2023
18:04
10:08
ManuFitbit
Yeah, sure…🙄
Sounds about right. Support is non-existent.
