12-07-2019 15:04
12-07-2019 15:04
Since the RHR is supposed to be more accurate than the MHR, why not use it. The device has already captured our Resting Heart Rate, so why not run it through the formula and base the daily heart rate graph on the RHR?
Best Answer12-07-2019 16:37
12-07-2019 16:37
The formulas I have seen that use RHR also require max heart rate.
What they do is just base heart rate zones on how far your heart rate is up as a % of difference between RHR and max HR.
But are you thinking of some other formulas and measurements?
Best Answer12-10-2019 09:02
12-10-2019 09:02
Best Answer09-05-2020 11:54
09-05-2020 11:54
@Mjshuster and @JohnnyRow -
Came across this thread while searching for a post on another thread...
For most devices and all devices prior to the Charge 4, the Traditional method of flat percentages of Max HR (50, 70 and 85%) for the three zones were used.
The Karvonen formula is what we have recently seen referred to as the "Heart Rate Reserve" formula here on the boards. The "new" formula used by the Charge 4 and now the Ionic and Versa family of devices.
For me, the numbers changed in the following way:
