12-18-2019 12:22
12-18-2019 12:22
I love my Fitbit One but I know it can’t last forever. I am looking at the Fitbit Inspire because I love the clip option. I have several clips for my One... will they work to securely hold the Inspire? Thanks.
12-18-2019 13:33
12-18-2019 13:33
Hi @Sullir - I never owned a "One" but I know that there were a lot of fans! The Inspire is not designed to be used with a clip, so while it may record your steps, I don't know how accurately it will track. I also don't think that it will automatically detect exercise unless it's on your wrist.
Happy Holidays to you!
12-18-2019 13:37 - edited 12-18-2019 13:39
The Inspire will not fit into the Fitbit one clip. It is a bit bigger. Sorry.
I tried as I have several One clips and I was afraid it would fall out because it did not fit snug
The HR model is not designed to use with the clip. But the regular one you need to buy the clip seperate
Wendy | CA | Moto G6 Android
12-18-2019 15:04
12-18-2019 15:04
I loved my ONE as well. So when it died i got the regular inspire. Without HR. A clip is made for it and it has an option on it that says, " On clip."
