07-25-2020
03:39
12:00
AlvaroFitbit
07-25-2020
03:39
12:00
AlvaroFitbit
I’ll charge my Inspire HR in the morning and wear it through the day and night. By the time I wake up the next morning the battery is between 70-75%. I’m charging this almost every other day. I don’t have a custom clock face, everything is standard.
Battery life has been bad from the start on the inspire and I was hoping a fix would come out but it has only gotten worse. My Alta was much better. This issue makes me regret “upgrading”
12:02
09:28
07-26-2020
12:02
09:28
@Winsdarling It's good that the community is growing!
Let me help you with your Inspire HR battery draining quickly. Try cleaning the contacts using cotton swab with rubbing alcohol, then charge it by plugging it for a couple of hours directly to your computer's USB port (try different ports) or use an UL-certified USB adapter. After this see how it behaves. You can follow these instructions to help improve the battery life.
Let me know how it goes.
Best Answer07-31-2020 03:35
07-31-2020 03:35
Thank you, I appreciate the advice. I tried your suggestions but they did not help.
Best Answer07-31-2020 06:32
07-31-2020 06:32
I did the same and it is draining daily since last weekend and getting worse each day.
Best Answer08-01-2020 01:07
08-01-2020 01:07
Best Answer08-01-2020 06:27
08-01-2020 06:27
07:49
06:58
08-12-2020
07:49
06:58
@MDFrustrated @Dipdap Welcome to the Fitbit Community! It's great to have you here!
Thank you for following my previous suggestions to help with your Inspire HR battery issue. @Winsdarling since the issue persists I have created a ticket so our Support team can further assist you via email. @MDFrustrated @Dipdap I noticed that you already have tickets with them so keep working with the team to find a solution.
Best Answer08-12-2020 08:06
08-12-2020 08:06
I have had my Inspire HR since last summer. All of a sudden last week it stopped holding charge. I have been through many of the feeds and it seems to me that this is an issue for many that has just recently started. Maybe there is a bug in the firmware...
I just charged my fitbit to 100% and unplugged it an hour ago, but just sat it on the counter to see how quickly the battery dies I am down to 86% without it even tracking anything. There seems to be no other way to contact customer service aside from this forum or waiting on hold for a long time. So here I am.
Is this a firmware issue and if it is can we reinstall the previous firmware until the issue is fixed?
Best Answer08-12-2020 10:31
08-12-2020 10:31
Best Answer08-12-2020 10:42
08-12-2020 10:42
Best Answer08-12-2020 12:57
08-12-2020 12:57
5 hours later, my fitbit is dead while sitting on the counter. That is a total of 6 hours of battery life while not tracking anything.
