Wake feature on Inspire HR is not working
Hi, for my device the screen double tap wake feature not working after July update. Just wondering if someone else is also facing the same issue... Thanks!
19 REPLIES 19
I'm having the same issue!
Yes, I'm experiencing the same problem
same, sometimes it works other times not. really spotty, and mine is brand new.
I have same problem
does anyone know if this is being fixed? Or how to go back to previous version?
thx
John
This is the response I got & so far it seems to be working. Good Luck
In order to solve the issues with your Inspire HR screen, please try to restart it with these instructions:
Plug the charging cable into the USB port on your computer or any UL-certified USB wall charger. Hold the other end of the charging cable near the port on the back of the tracker until it attaches magnetically. The pins on the charging cable must connect securely with the port. Press and hold the button on your tracker for 5 seconds.  Release the button. When you see a smile icon and the tracker vibrates, the tracker restarted.
You can also try to change the clock face of your device. Your device should now work normally.
Kat, worked for me - thank you for the info!
thx
*You’re all trim tabs man! Tag, you’re it!” *
The Dude
I tried this but still it didn't fix the issue.
Moving the wrist everytime is annoying.
Anyone else found a solution?
You can always just press the button to see vs using the double tap feature, I honestly think its a defect w/the product because I had mine replaced as I had only have it s mos into the issue happening & guess what, it's still happening with the replacement, hence why I think it's just a product defect.
I think it's a bug. Maybe it'll be fixed in next firmware update.
Does fitbit roll out updates frequently? I'm new so I was wondering.
Even that doesn't work for me. Only the button does.
When I am swinging my arm for time I usually don't have access to my other hand to hit the button.
Double tapping and swinging arm don't work.
Sorry for all the posts, new here.
Same problem here😭
I'm so glad I found y'all!  Visualizing everyone swinging & tapping & pushing for screen has me in tears😂😂
Mine is the same but I didn’t know what it does and when I turn it off I double tap to turn on and it works off it does nothing for me
Mine seems ok but 🤞does not play up
I figured it out. Sleep Mode was turned on. Swipe left until you see settings and then turn sleep mode off.
Sleep mode on--turned off--now working with double tap.  Thanks
