04-04-2019 21:28
04-04-2019 21:28
Does anyone wear their Inspire HR on the inside on their wrist? I find it a lot more comfortable because I have tiny and skinny wrists but I wonder if that effects the stats? I noticed their was a huge difference while working out with the HR reading.
04-05-2019 08:25 - edited 04-05-2019 08:28
Hi @Innafit, thanks for joining this family, hope you like what find here!
Congrats on your new Fitbit. I'm glad to see that you are using the new Inspire HR. About your accuracy inquiry you can take a look of this article to know more about it: How accurate are Fitbit devices?
In case that you think your Fitbit Inspire HR is not a good options for you, take a look of the clip option for Fitbit Inspire. Please note this only works with Inspire. If you prefer to use your Fitbit on your wrist I'd suggest the Fitbit Versa, since I also have a very tiny wrist and it has worked perfectly for me.
I hope to keep seeing around.
04-05-2019 13:20
04-05-2019 13:20
Thank you for taking the time to reply. Unfortunately the Versa is bigger than I want. But I was wondering in terms of do you know if there is a difference between wearing on the inside of the wrists vs on the outside.
04-05-2019 22:52
04-05-2019 22:52
Hi @Innafit As far as i am aware, no there is not. Some people have reported wearing theirs on the inside with good results. I am an outside wearer, but wore it on the inside overnight once to see how it performed tracking sleep and it worked well.
Helen | Western Australia
