08-30-2019 11:38
08-30-2019 11:38
I was wondering what all it will erase if I erase data
08-30-2019 12:01
08-30-2019 12:01
Hi @vanloon Can you be a bit more specific? Are asking about doing a factory reset on your Inspire? If yes, then it will erase all your customized settings, like alarms and notification. It will not remove your personal data/history from the Fitbit app. I hope that helps.
08-30-2019 13:53
08-30-2019 13:53
@MarciM I’m talking about the thing in the settings on the Fitbit itself that says clear user data
08-30-2019 14:10 - edited 08-30-2019 14:11
You only want to do this if you have credit card info on it and things like that
This article will help you understand better
Wendy | CA | Moto G6 Android
