04-07-2019 05:59
04-07-2019 05:59
Can this be done?
When I got to the app notification menu, WhatsApp is not there to be selected, this had been the same for two weeks since purchasing, I've tried send test WhatsApp message from different phones, but the app does not appear on there menu?
Any thoughts
Thanks
Michael
Best Answer04-07-2019 08:46 - edited 04-07-2019 08:49
Hi, @michael_s_king , yes, whatsapp notifications definitely available. What phone / OS are you using? Someone should be able to give yu full instructions.
Basically you can choose between Whatsapp being yur orimary messenger service, or keeping with SMS and adding Whatsapp as an App notification. I use the latter, and it works well.
Edited to add: WhatsApp will not appear on the list until you have rceived at least one Whatsapp message on yiur phone.
Best Answer04-07-2019 10:06
04-07-2019 10:06
Phone is up-to-date iOS
I've sent test WhatsApps and it's not appearing on the list of app notification, although other apps are ??
This works fine on my charge 3, with my iPhone , Just not my wife's inspire HR with her iPhone ?
Best Answer04-08-2019 13:17
04-08-2019 13:17
Any more suggestions from anyone ?
Best Answer04-10-2019 03:21
04-10-2019 03:21
How do I choose Whatsapp as my primary messaging option? I'm only seeing it as an app. Thanks
Best Answer04-10-2019 10:50
04-10-2019 10:50
I don't even see it as an app 😞
Best Answer05-01-2019 08:47
05-01-2019 08:47
Hi,
Having used a Pebble watch for quite some time, I found this quite tricky and non-intuitive at the beginning, also. Apparently your Fitbit app has to 'learn' which apps create notifications. This is what worked for me:
>On your iPhone<
Step 1. Open 'Settings'
Step 2. Make sure Bluetooth is on and paired with your Fitbit Inspire HR
Step 3. Make sure the apps that you use appear as notifications on your phone (strokes, badges,... etc.). I wanted WhatsApp and Mindful Me to send notifications to my Fitbit.
>In your Fitbit app<
Step A. From your Dashboard go to your 'Account'. It's the little card icon on the upper right corner.
Step B. Select your device 'Fitbit Inspire HR'
Step C. Go to the bottom of this menu and make sure synchronization is set to continuous.
Step D. I use a Dutch menu but probably in the English version you's see something like 'Notifications' in the list as well. Select this one.
Step E. You see three buttons/options (smth. like calls, sms-notifications and calendar events). Below that you select 'App-notifications'.
Step F. Here's a list of apps that can send notifications to your Fitbit watch. WhatsApp wasn't shown to me in the first place, because the Fitbit-app has to 'learn' apps can send notifications. Only after performing up to step C. I was able to see WhatsApp pop up in this list after a friend sent me a message (yeah, it's quite dreadful that you have to wait for this. Same goes with the Mindful Me app. Facebook messenger, Twitter etc. I'm waiting for these apps to send me a notification so I can activate these as well).
Last but not least >On your Fitbit watch<
-Press the side button for a couple of seconds, browse to the bottom and make sure that the notification function is on.
Hope this helps for you as well!
specs:
-iPhone 6s (iOS 12.2)
-Fitbit Inspire HR ver. 20001.60.39
-Fitbit app ver. 2.92
05-12-2019 19:22
05-12-2019 19:22
I had similar problems on my first day, after calling fitbit helpdesk did not get much help and the guy deliberately hung up as he could not resolve the issue.
For iOS device To see any app in fitbit notifications for selection, you need to set the notification on for that app, while doing this make sure that you also check alerts appear in “Notification Center”.
After this get a notification for that app and this app will appear for selection under notification for the device in fitbit app.
05-13-2019 11:19
05-13-2019 11:19
This was a great help! Thank You!
01-09-2020 07:04
01-09-2020 07:04
I just purchased an inspire HR I don’t have any exact same issue. Michał did you ever resolve this? I’ve received Mini WhatsApp notifications but it’s still not showing up in my available apps list.
Best Answer01-09-2020 10:55
01-09-2020 10:55
I fixed it in the end, I had the wrong notification setting on my phone
Best Answer01-09-2020 15:54
01-09-2020 15:54
