Where I can find my previous step data?
At noon my Fitbit reset my steps. Now my workout this morning is NOWHERE. Any advice or way to get it back?
2 REPLIES 2
Hi @Cadenf nice to see you on the Fitbit Forums. I'll be glad to give you a hand with your inquiry about where you can find your data from other days.
Thanks for posting your question here, as you mentioned above your Fitbit device resets your data to zero each night at midnight. Your minute-to-minute data is stored in your Inspire HR for up to 7 days without syncing, I'd suggest to sync your Fitbit device then check the step tile on your Fitbit app to see previous days.
Let me know if this helped.
Apparently @Cadenf tracker is not resetting at midnight. But red setting at noon.
My thought would be to check yesterday for the exercise.
