04-03-2020 17:10
04-03-2020 17:10
Does the inspire HR or fitbit app save text messages after notification? (meaning the content of the messages, not the notification a message is received). Where can I find messages to read after the quick notification? Thanks.
Best Answer04-03-2020 17:49
04-03-2020 17:49
If your reffering to text messages from your text application. The Inspire does not save them.
The app doesn't display them.
If your reffering to Fitbit messages, they are saved in your in folder on Fitbit.com or the Fitbit app.
Best Answer04-03-2020 18:20
04-03-2020 18:20
Yes sorry I am referring to texts from my iphone.
Are you sure? Sorry to ask again but two fitbit reps in support told me that it saves my text messages from my iphone. but I can't figure out how to do it.
Best Answer04-03-2020 18:25 - edited 04-03-2020 18:26
If your reffering to your messages from your message reader. No I don't think that they are saved on the Inspire or Inspire HR. If they are you would swipe down on the screen.
They are saved on the Versa and Ionic line.
Best Answer04-03-2020 18:37
04-03-2020 18:37
Sorry not sure what message reader is. referring to iphone . thanks for quick responses!!!
Best Answer04-03-2020 18:44
04-03-2020 18:44
The text messages that are sent to your phone number.
Best Answer04-04-2020 06:56
04-04-2020 06:56
@Wondering45 No, the Inspire series does not save your text messages like the other Fitbit models.
The way other models works, like the Charge 3 for example, is that if you swipe down from the top, you're shown your old messages you haven't opened yet. However on the Inspire devices, when you swipe down from the top, you are presented with your different apps (exercise, relax, etc).
In short, the Inspire does not store or save old text messages like other Fitbit devices.
04-06-2020 17:40
04-06-2020 17:40
Thanks for everyones responses. The fitbit support rep seemed very confident my messages would be saved in the app and the fitbit device. Now I am confused!
Best Answer04-06-2020 18:11
04-06-2020 18:11
Notifications from third I try apps are not saved in the Fitbit app. Your inspire only shows notifications when sent.
Fitbit. Community and Fitbit private messages are saved on the Fitbit server and the Fitbit app can pull them up.
Best Answer04-06-2020 19:04
04-06-2020 19:04
thanks for the response
