10-19-2022
03:46
20:58
10-19-2022
03:46
20:58
Can someone please tell me where to find a correct charging device for a Fitbit Inspire 2. The replacement changer for Inspire 2 & Ace 3 does not work. I can not find the original magnetic charger anywhere. Is Inspire 2 so outdated that this is not avaiable anymore? I live in Germany.
Thanks!
10-19-2022 18:44
10-19-2022 18:44
@Odyssey13 , Thank you for the information shared
The charging cable for the Inspire 2 on our German store can be found here: https://www.fitbit.com/global/de/products/accessories/inspire2-charging-cable?sku=177RCC
If you purchased it here, please contact our team, and let them know that it didn't work.
In the meantime please verify that the contacts on the Charging cable and on the tracker are clean. Try rubbing a clean dry q-tip if needed.
Our contact info for Germany, can be found here:
See you around.
10-19-2022 09:31
10-19-2022 09:31
Hi @StineW you order that charger that didn't work from Fitbit.com? I have the link to the store site which sells it and it appears to be the only charger for the Inspire 2. Since you're in Germany, I'm not sure where you would go, so I've asked a moderator to stop by to assist you.
10-19-2022 18:44
10-19-2022 18:44
See you around.
10-23-2022 05:09
10-23-2022 05:09
Thanks for your support! I finally found an replacement charger and my Fitbit is working again 😊
10-23-2022 05:40
10-23-2022 05:40
I love good news. Thanks for the update @StineW
