10-13-2020 20:39
10-13-2020 20:39
So heart rate is visible on the dashboard as a widget. You click on the widget and below it, "See more" is displayed. You click on "See more" and it takes you to the Logs page where you can filter different data by time. There is Food, Activites, Weight, Sleep but no Heart Rate.
I want to filter Heart Rate data the same way I can filter the other data. Why does the widget redirect to Logs when there are no heart rate logs? Heart rate logging is the only reason I purchased this device and there is no detailed logging available. Why?
Best Answer10-13-2020 22:20
10-13-2020 22:20
That graph on the dashboard before you clicked on "See More' is the best view of heart rate. Near the top left beside 'Today' is a little calendar. When you move your mouse over it, it changes to arrows to move back or forward a day at a time. And as you move your mouse over the chart, it displays the exact readout.
Is there something else you are looking for? If so, exactly what?
Best Answer10-14-2020 09:01
10-14-2020 09:01
The widget interface isn't great and you can't filter by specific dates. Detailed logging of heart rate from a heart rate tracker isn't a radical request.. There are logs for Food and Weight which having nothing to do with tracker but no logs for one of their flagship feature? I can see why they're falling behind.
