11-21-2019 13:36
11-21-2019 13:36
Just got my Inspire Fitbit today. I have followed all the steps and everything is set up but it's not connecting as there white line on the screen and nothing else. Don't know what to do
07-30-2020 08:00 - last edited on 09-17-2020 12:22 by LiliyaFitbit
Log into Fitbit in your phone. Have the Fitbit connected to a tablet or computer via usb connection. Remove any Fitbit inspires that you see in the account if any show up. Then add a new Fitbit (the new one). Make sure any Fitbit inspires that are charged and working aren’t in the house when you do this otherwise it won’t work. When I did my friends I had to put mine outside in my car so it wouldn’t interfere with the setting up of hers.
Then start the process leaving the Fitbit attached to the charger. We found that it wouldn’t start downloading the firmware update to the inspire until it was 60% charged. It can take quite a while for it to download and and update the inspire. I think my friends took about 45 minutes. We went and had a catch up while we waited.
Hope this helps.
Jan
Get Outlook for iOS
07-30-2020 13:31
07-30-2020 13:31
Followed your instructions and connected it to my iPhone. After the download and installation was complete I was able to re-pair it back to the computer and now it works. Thank you.
07-31-2020 18:29
07-31-2020 18:29
this did not work for me at all
08-13-2020 17:12
08-13-2020 17:12
Like many others, I got the "white line of death". After two hours of trying to set up the Inspire HR I finally stumbled upon the solution:
1) Place your new Inspire HR into its plugged in charger and let it fully charge (some say 50% or 60% if fine, but why argue with success)
2) Hide all other FitBits somewhere else in the house. No need for conflicting devices!
3) Do NOT go to fitbit.com/setup on a PC or MAC! I tried both and neither works. Ignore the scrolling message on the Inspire HR. Only the cell phone route worked for me!
4) Go to Google Play or the Apple store and search for the FitBit app. Download, Install and Open.
5) If this is your first FitBit then you will need to set up an account using an email address and password. Follow the procedure. All others can sign into the FitBit application.
6) Click on the circular "person" icon in the upper left corner.
7) Under "Set up a Device" select "Inspire HR".
😎 Important! Take the FitBit out of the charger! It didn't work for me while it was in the charger!
9) Accept the agreement and follow the instructions on each screen. At one point a four digit number will appear on the FitBit screen. Type that number on your phone.
10) Next you will see a download start on your phone. It will proceed to 100%. Following that, an install will proceed to 100% As this is happening, the pesky white line will act as a "thermometer".
11) Finally your FitBit will be ready for use. Let FitBit know their installation procedures and lack of documentation is really POOR!
08-13-2020 18:02
08-13-2020 18:02
Okay...this crazy! The same thing is happening to me! I've talked to customer support, tech support and at the end, I'm told its updating....
1hr, 2hrs, 3 hrs, 4hrs later, still updating?
I'm thinking it's just defective and should be taken out of the lineup.🤷🏿:female_sign:
09-05-2020 11:40
09-05-2020 11:40
This was purchased for me as a gift. I do not own a cell phone so therefore that is not an option for me. If anyone figures out a solution that does work with a PC that would be great. Thanks!
09-05-2020 15:07 - last edited on 09-17-2020 12:22 by LiliyaFitbit
I would call Fitbit for assistance and direct them to this post. It isn’t a malfunction with the device. It is a problem with their installation platform.
Jan
09-14-2020 12:55
09-14-2020 12:55
It's a never-ending process. The white line on the screen is what I paid for. Waiting for a replacement with less hopes on the product now.
09-14-2020 17:35
09-14-2020 17:35
I've already received the replacement and it was no better than the original. Never mind that the outside of the box indicates it is compatible with Windows 10 machines, the fact is that you cannot setup an InspireHR with a WIndows 10 machine. Not everyone has or wants a smart phone, yet support's only solution to the problem is "borrow" a smart phone or return to retailer. Why is it so difficult to just send the device with the most recent version of the firmware???
09-16-2020 14:50
09-16-2020 14:50
Best Advice! I had this problem and customer support couldn't even help me. I was using my computer to set up my fitbit. Once I removed it and set it up using my phone, it downloaded an update which took less than 30 minutes and then my fitbit worked.
10-19-2020 14:53
10-19-2020 14:53
Thank you for this. Mine said it was charged 100% so I removed it from the charger and also got the white line. Then it said it was 98% charged. I popped it back on the charger and we'll see what happens.... I'll wait for the line to grow.
10-19-2020 15:03
10-19-2020 15:03
Did you vote yourself as the best answer? This has only one vote and it does nothing to answer the question. Ridiculous.
10-19-2020 15:22
10-19-2020 15:22
Just try making sure I t is at least 60% charged and do the setup through the phone it works. See posts above.
10-28-2020 16:19 - edited 10-28-2020 19:18
Tried ALL the above. Nothing worked. All the Inspire HR shows is the horizontal white line. Tapping, holding down the button - no effect. Reinstallation of the apps both on the computer and on my smart phone - no effect. Phoned Fitbit tech support - had a lady guiding me for an hour - useless, no result. Returned the Fitbit and got a replacement - exactly the same result - the horizontal white line or black screen.
Solution: return the product, get money back, and use a completely different brand.
Fitbit need to wake up!
Update - have returned Fitbit and got a Garmond instead. No more Fitbit for us.
11-08-2020 22:20
11-08-2020 22:20
Don't know if this is same issue. Wasted 6 hours of my life trying to get it to work.
It synced to my PC after I went through all the steps but after resetting multiple times still only ended up with a white line across the screen - no clock, nothing, just a white line. Next day I again removed it from my fitbit account but instead downloaded app onto my android tablet. This time it said there was an update and it downloaded, installed and worked! The white line turned a grey one and gradually moved to white as update downloaded and installed.
Reason I am advising this it was never mentioned in the 100s of tips/solutions I read. Surely this is not the first time this has happened?
If you don't have a second device see if a friend can set it up and then just reset. Once it is initially updated it should work...one would hope.
Good luck!
01-03-2021 08:23
01-03-2021 08:23
jeez...what a pain. so I had to setup on my "phone" and an "update is due" was in an area as a scrolled across new information. I had to tell it to do the update. it was not automatic. the line is moving (getting fatter on one end). the device is still plugged into my computer for final charging (at 85%)....but the phone app was where I had to give permissions, after finding it , to do the update.
01-08-2021 01:16
01-08-2021 01:16
Well done debnjesus, you nailed it. Can't believe they have neglected the windows interface for that initial set-up, but the phone route worked. Bizarre they never mention the potential requirement for an update, or that a totally non-responsive white line isn't a screen of death. It nearly got returned to the shop as busted...
01-08-2021 03:39
01-08-2021 03:39
Done all that but .... nothing
01-20-2021 13:51
01-20-2021 13:51
Thank you for the info, I was having a issue and your step by step helped me get mines set up.
