Why doesn't my fitbit tell me to move anymore?
ANSWERED
It's been weeks since I got a little buzz reminding me to move.
1 BEST ANSWER
Accepted Solutions
Figured it out.  I must have accidentally turned on DND while trying to get it to show me the time, which takes several taps sometimes.
8 REPLIES 8
Hi @ramonv  I'd suggest you start by checking that reminders to move haven't accidently been turned off.
In you app, tap the reminders to move tile (a brown man in a  circle). Then tap the gear icon and turn reminders to move on or off.
If that doesn't work try restarting  your Inspire a few times and see if it works then.
Restart your Tracker
Community Council Member
Helen | Western Australia
When is the Inspire 2 supposed to alert you to get moving? Does the step count have anything to do with it?
Thanks, but I can't find the brown man in the circle.
If I did find him (not sure), I can't find anything at all about reminders.
I wouldn't know.
I think I found it, but it appears it was on already, so who knows.
Yes, @dklassen - Steps have everything to do with reminders to move. If you have not recorded at least 250 steps in the last 50 minutes, your Fitbit can give you a reminder to take the remaining steps needed to reach that goal. If you have reached or exceeded the 250 step goal, you will not receive a reminder. You can read more about this here
Except that mine doesn't send reminders anymore, nor does it tell me when the battery is dying.  5 months old, and half the features don't work.
