04-17-2019
15:44
09:04
AndreaFitbit
04-17-2019
15:44
09:04
AndreaFitbit
Hi!
I have upgraded my Flex (after 4.5 yrs) to an Inspire HR yesterday. The upgrade & device registration went great!
Will the computer fob / dongle that connected & synced my Flex be able to perform a sync with The Inspire? I have tried via the Windows 10 App and it always fails with "Device Not Found"
Thanks!
Steve
Best Answer04-18-2019 09:09
04-18-2019 09:09
It's nice to see you back @SteveReiss. I'll be glad to assist you with your syncing your Inspire HR with the dongle you used to sync your Fitbit Flex.
Make sure that you have installed the Windows 10 App and not Fitbit Connect on your computer. If you complete the requirements you should be able to sync your Inspire. Please check help article Why won't my Fitbit device sync?
Let me know if you need further assistance.
Best Answer04-21-2019 08:50
04-21-2019 08:50
After a couple of days and a few more tries, the Inspire HR is now syncing on my Win10 machine with the old dongle. I did not do anything different...
Best Answer08-02-2020 11:14
08-02-2020 11:14
I tried it with the FitBit connect and it syncs fine.
Best Answer08-02-2020 11:34
08-02-2020 11:34
I use a dongle for my newer fitbit and was disappointed to find that the fitbit had to be within inches of the dongle for it to work or i would get the same error message. The cable length on the magnetically attached power charger is ridiculously short as well.
Best Answer08-06-2020 11:28
08-06-2020 11:28
Thanks for getting back to us @SteveReiss, @sacdadi522 and @Bill_k. I'll be glad to continue assisting you with your syncing with your syncing with your dongle inquiry.
@SteveReiss, I'm glad to hear that you were able to sync your Inspire HR with the dongle without doing anything.
@sacdadi522, thanks for letting us know that it syncs fine with Fitbit Connect.
I appreciate your feedback regarding proximity to sync and the charging cable @Bill_k . We take our customer's feedback into consideration for future products improvement.
Keep on visiting the forums.
Best Answer08-06-2020 11:56
08-06-2020 11:56
Thanks for these recent posts... I have long since resolved this issue.
Best Answer08-06-2020 14:02
08-06-2020 14:02
Hey @SteveReiss. I'm sorry for the delay, I just returned from some time off of Fitbit and I'm replying my posts.
Keep on visiting the forums! 😁
