10-19-2020 00:53
10-19-2020 00:53
Brand new. Everything else working but screen won't come in when I turn my wrist and I'm having to tap several times before it comes on.
Husband received same Fitbit at same time and his does this no problem.
Fitbit Inspire.
10-19-2020 09:37
10-19-2020 09:37
When this happens to me I push the button on the side to show the battery life, then tap the lightbulb icon which appears below the battery indicator. Click the button again to back to your normal display, then try lifting up your wrist. That always solves the problem for me.
10-19-2020 05:48
10-19-2020 05:48
Curious about this as well, mine no longer does this.
Best Answer10-19-2020 09:37
10-19-2020 09:37
12-05-2020 05:23
12-05-2020 05:23
Did not work for me
Best Answer02-05-2021 05:46
02-05-2021 05:46
I scrolled right on my Versa to select the Settings icon, then down to Screen Wake & chose Auto (motion).
Best Answer02-05-2021 06:39
02-05-2021 06:39
Thank you! This solved my problem also!!
Best Answer02-05-2021 06:40
02-05-2021 06:40
Thank you!!! This worked for me.
