04-27-2019 16:32
04-27-2019 16:32
I have an Inspire HR that was working fine up until I updated to the latest version yesterday. Since the update, rotating my wrist doesn't turn it on.
Is there a way to fix this? I can't find any configuration options for this in the phone app or fitbit.
04-27-2019 17:00
04-27-2019 17:00
Hold in left button a few seconds. Below battery, see 'Screen Wake'. Tap to toggle on or off.
I have read of updates sometimes messing with settings but no idea if that was the case this time.
04-27-2019 17:00
04-27-2019 17:00
04-27-2019 17:07
04-27-2019 17:07
That was it, thanks!
07-31-2019 06:15
07-31-2019 06:15
Hello, I have the same issue. My screen does not come on when I flick my wrist. I held the button on the side and the battery came on but the screen still does not work. Can you help me with this?
07-31-2019 07:00
07-31-2019 07:00
After you hold down the button and the battery appears, there should be an icon below it that looks like a light bulb. Tap that icon on the screen to toggle it on/off.
07-31-2019 07:20
07-31-2019 07:20
@AMR756 wrote:Hello, I have the same issue. My screen does not come on when I flick my wrist. I held the button on the side and the battery came on but the screen still does not work. Can you help me with this?
Holding in the side button takes you to quick settings. From there, you might have to scroll up or down to get to 'Screen Wake'.
10-31-2019 16:35
10-31-2019 16:35
Tap the lightbulb below the battery that appeared.
01-28-2020 20:46
01-28-2020 20:46
why
did
fitbit
make
this
SO **ahem**
hard
to
find??????????
06-01-2020 12:46
06-01-2020 12:46
Thanks it worked..
09-09-2020 09:56
09-09-2020 09:56
This worked! and it was so simple. Thank you Johnnyrow!
