Wrist too small for Inspire HR band?
Hi!
I have recently lost several pounds. My wrist used to be about 5.75", but it's now more like 5.4" (I have a small frame). I moved from the third-tightest setting on the small wristband to the second-tightest, and will soon have to move to the tightest. Are there any options for smaller bands in the event that this becomes an issue? Maybe custom bands?
I'm also planning on replacing my Inspire HR with a Charge 3 soon because my Inspire HR perpetually misreads or stops reading my heart rate and generally malfunctions. Does the Charge 3 have any options for smaller wrists, or just the same "small" and "large" bands?
Thanks!
1 REPLY 1
@mbv23 It's good that the community is growing! Sorry for the delay in my reply.
First of all congratulations on your weight loss and hope you keep reaching your goals and be a healthier version of yourself. Thank you for your inquiry. Currently this isn't available but you can share your idea in our Feature Suggestions board. Search for the idea first to see if one already exists so you can add your vote. The more votes an idea gets the more likely the developers will try to implement it.
Regarding the heart rate reading on your Inspire HR I suggest you clean the back of your device with cotton and rubbing alcohol and restart it. Turn the heart rate off, save and sync then turn it on save and sync again. Also check these tips to improve the heart rate reading on your device.
Let me know how it goes.
Alvaro | Community Moderator
