08-06-2019 03:23
08-06-2019 03:23
I've got my amount of daily steps set at 10,000 but I want to increase it to 12,000 how do I do this? thanks in advance.
Best Answer08-06-2019 04:41
08-06-2019 04:41
@carina61 Tap on your steps icon on your dashboard. Tap on the gear icon. Now you can change any of your goals. Whenever I change my step goal, I also change my distance goal. It keeps the two goals matched.
Laurie | Maryland
08-06-2019 04:41
Laurie | Maryland
Best Answer08-06-2019 05:59
08-06-2019 05:59
what do you change your distance goal to? if I changed it to say 11,000 or 12,000 daily steps goal?
Best Answer08-06-2019 08:18
08-06-2019 08:18
@carina61 Most average height adults take slightly more than 2000 steps per mile. So a fair place to start will be 6 miles with a 12,000 step goal, but be ready to tweak it. Fitbit uses a steps x stride length to calculate your distance. But your natural stride length is different at a 3 mph walk compared to a 4 mph walk. So it it can take a little fine tuning to make the goals close to each other. I also want to add that if you use the Exercise app with a GPS connected walk or run, Fitbit uses the GPS measured distance. The exact same walk with and without GPS can have two somewhat different distances.
It is never a perfect match. I just want them close.
Laurie | Maryland
