08-01-2019 09:28
08-01-2019 09:28
Does the inspire HR come with a dongle like the previous fitbits? or is the dongle and charging cable combined? thanks for advising
Best Answer08-01-2019 11:13
08-01-2019 11:13
No Fitbits come with the dongle now. I almost said you can buy them separately from the Filbit store here, but just checked and don't see them - don't know if that is temporary or permanent. But you can find them on Amazon.
08-01-2019 11:41
08-01-2019 11:41
thank you for your reply. So i did not accidnelty lose the dongle when unpacking my new toy.... Inspire HR 🙂 I have a dongle from flex2 i wonder if that might work?
Best Answer08-01-2019 11:48
08-01-2019 11:48
I believe the dongle is device-independent; i.e. the same for all devices.
Best Answer08-01-2019 13:02
08-01-2019 13:02
As @JohnnyRow said, I think the Dongles are device independent. That said, the real question is "why do you need a dongle?". The current fitbits are designed to sync with a phone, tablet or PC via bluetooth and it only needs to work with one device for you to keep it synced. You can check here if you have a supported device.
Best Answer08-02-2019 09:28
08-02-2019 09:28
It is not the tracker that needed the dongle, but the Fitbit connect software for an older version of the windows operating system.
As long as the computer is a Mac or a win 10 with built in Bluetooth. A dongle is not needed, but yes tye one from the flex will work.
Best Answer11-11-2019 07:37
11-11-2019 07:37
Fitbit Help reports Fitbit Connect can be used for win 8.1 laptops when following the Inspire HR limiter at help.fitbit.com. Downloaded Fitbit Connect program and installed on win 8.1 laptop. Can see the Inspire HR as a bluetooth device, but will not pair via Windows. The Fitbit Connect program leads to a limited selection of Fitbit products - not including Inspire HR. Therefore cannot proceed to setup. Conflict of help support information. Have Windows 10 computer, but no installed bluetooth. I see wi-fi dongles and bluetooth dongles on Amazon. If I must give up using the laptop, I must select a correct dongle and then download the Fitbit app to the Win 10 desktop. Must I give up on laptop? If so, what is correct type dongle? I have zero interest in constant display of data on a smartphone. Only in downloading historical data for my review - like sleeping heartrate. Hoping for some adult guidance. Thanks.
Best Answer11-11-2019 08:08
11-11-2019 08:08
Hi @Bill-Win-8-1 The fitbit connect with windows 10 does not need a dongle if Bluetooth is built in or may use a standard Bluetooth dongle.
As for 8.1 I'm not sure if it needs a fitbit dongle or not. Since I have not heard of the Inspire limiter process, without a link to the help doc I'm unable to comment.
However the fitbit connect is designed to work with all models of Fitbits, and the setup steps listed in the help doc for Win 8.1 seem to imply any dongle will work, I would try an off the shelf dongle.
Best Answer11-11-2019 12:17
11-11-2019 12:17
Best Answer11-11-2019 12:24 - edited 11-11-2019 12:27
@Bill-Win-8-1 I'm assuming you do not have a smart watch. If so, your Windows 10 desktop is definitely the way to go, at least for set-up, and forget the dongle. Download the Fitbit app from the Microsoft store and go from there.
We're not Fitbit employees and definitely not claiming the documentation is perfect, just other users sharing our experience trying to help each other.
Best Answer11-11-2019 17:48
11-11-2019 17:48
According to the doc that is referenced. The user is not suppose to try and pair the tracker using the computers Bluetooth, but will do all the setup through fitbit connect or the Fitbit Win 10 app.
The exe file that was downloaded should be Win Connect.
