05-25-2019
08:47
10:51
AlejandraFitbit
05-25-2019
08:47
10:51
AlejandraFitbit
Best Answer05-25-2019 15:16 - edited 05-26-2019 06:14
Hello @bg58 and a warm welcome. Please go to page 13 of the Inspire HR Manual. The pin is spring loaded, so you need to press down on the "ball " of the pin to pop the band out. I don't like the re-attaching diagram. It shows the pin at a very sharp angle. That angle is too sharp -- You risk bending and breaking the pin. I broke a Versa pin by putting it in at the wrong angle.
Laurie | Maryland
Laurie | Maryland
05-26-2019
10:52
12:56
05-26-2019
10:52
12:56
Best Answer09-11-2019 11:41
09-11-2019 11:41
Pressing the pin did not release the wristband. I tried pressing it "in," which would be toward the Fitbit, and when that didn't work, I pressed "down" (toward bottom of band), then "up," and nothing worked.
Best Answer09-20-2019 12:12
09-20-2019 12:12
slide your tiny balls to the center, then pop out the side where the balls came from.
09-20-2019 12:54
09-20-2019 12:54
Best Answer10-30-2019 06:23
10-30-2019 06:23
THANK YOU!!! This was the best explanation. 🙂
