09-01-2023 05:59
09-01-2023 05:59
Since 19 August, my inspire 2 has stopped recording my sleep data. When I tried to manually add data for 20 August, it tells me there is already data.
My daughter bought this for me in July, and I have had no problem until this. I have rebooted, logged out, turned GPS and heart off and then back on but nothing. I specifically use this to track my sleep as I have Parkinson's. Please help!!!
09-01-2023 09:14
09-01-2023 09:14
Good to see you participating in the community for the first time @SLYM.
Thank you for sharing the inquiry regarding this inconvenience with the device and for trying to fix it trough the steps mentioned.
When your body is completely at rest and you haven’t moved for about an hour, your device should record that you’re asleep. Please keep in mind that there are some factors that may prevent your tracker from recording your sleep. Please make sure of the following:
Please, try to perform a restart one more time. In addition, please wear your device on your non-dominant hand and monitor it for the next few days.
