09-23-2019 06:00
09-23-2019 06:00
Woke up this morning and the display isn't working. The main face shows up, but the scroll won't work, and pressing the side button doesn't show the battery. Tried to reset and nothing happens. I've only had this one for a few months. Suggestions?
Thanks
Best Answer09-23-2019 06:33
09-23-2019 06:33
I'm having the exact issue. Mine started last night. I've only had mine for 6 months.
Best Answer09-23-2019 07:03
09-23-2019 07:03
I've got exactly same problem. Started 1 hour ago.
Best Answer09-23-2019 07:38 - edited 09-23-2019 09:09
Now I've noticed it isn't tracking step or HR. Because I can't scroll up, I can't do a factory reset.
UPDATE: As mysteriously as it stopped, it's now started. Lost steps at the store, but everything else seems to be normal. Except the sleep icon. It's always 50/50 if that works. 🙂
