01-17-2020 11:05
01-17-2020 11:05
I have a fitbit inspire hr brand new out of box. I charged it over night using a usb cable. That did nothing. Then I charged 24 hours with a 5volt charger.
When I try to update the firmware it says the battery doesn't have enough charge. When I try to turn it on with the switch it lights up but will not display the options available.
Any suggestions.
Thanks, Richard
Best Answer01-17-2020 11:13
01-17-2020 11:13
Richard here.
I tried to reset the device. After holding the button I get the first screen with the dots and "www.fitbit.com/setup" crawling across the screen.
Best Answer01-17-2020 11:17
01-17-2020 11:17
back to the usb port. reset device. got the smiley face, 94% charged. That's all I can get out of it.
