"Check Charger Battery is not charging" on Inspire 2
"Check Charger Charger is not working" appears when I plug into wall outlet! THANKS FOR ANY PROMPT ASSISTANCE!
1 REPLY 1
@Gmc2018  Does the same thing happen in different wall outlets or with different charging boxes or USB ports?  Please try cleaning the charging contacts on your Inspire 2 with some alcohol and a toothbrush.  Gently clean the pins on the charger with alcohol and a cotton tipped applicator.  Look at the pins on the charger and make sure they haven't been damaged.  Users of other models have reported that a charging pin got depressed in.  I haven't read a report like this with the Inspire 2.  If the charger is damaged, you will need a replacement.
Laurie | Maryland
