replacement Inspire HR does not fit original Inspire HR bands
My Inspire HR refused to work after 4 months of purchase.  I texted Fitbit and they sent me a replacement Inspire HR - but the one of the bands did not quite fit. I know how to change bands (my family has several) so its not that. But I realize that replacement has a groove is slightly bigger than the original one (where you insert the clip/rod) and there by making it loose.  I can wear it as long as I don't run or jog or hit a laptop while typing or it falls off.  Any hints?
3 REPLIES 3
Hi @jandon  the band you're using, is it an authentic Fitbit one? Some bands are from third party sellers and might not fit properly.
Stepping in the U.S.A. since September 2013. Android 14
@Odyssey13 it is an authentic fitbit one. Bought it from fitbit store on amazon.  and the wrist band disconnected from the fitbit earlier today in mid stride (walking) so its difficult to wear with out worrying it will fall off.
@jandon  glad you're careful with your Fitbit. See if support can help you out.
Fitbit customer support is doing their best, but right now be prepared for longer wait times. Please be patient. Support is limited by the number of representatives available at a given time and the hours of operation. Chat lines are open when they have live help.
USA: call (877) 623-4997
UK: call 0800 069 8505
INDIA: call 000 800 050 1057
IRELAND: call 01 691 7502 (country prefix: +353)
Other contact options:
USA: click
Canada: click for options
