08-30-2019 11:14
08-30-2019 11:14
How do I get the inspire to recognize time spent on the stationary bike?
08-30-2019 13:05
08-30-2019 13:05
@Linda44344 Just to clarify, you say you have an Inspire, not an Inspire HR. Stationary bike is not one of the auto-recognized activities. You will need to log it manually. To log an exercise, tap on your exercise tile > tap on the stopwatch > slide the toggle to LOG. In the Search for exercise type field, type in Spinning. I use an iPhone and I have two choices. One just has a start time and duration. If you have a bike that gives you a calorie burn or distance, then the other choice has fields where you can enter that information. I do not know if the Android app is the same.
I hope this helps.
Laurie | Maryland
