wrist flick to get display?
ANSWERED
On my Alta HR I could raise and twist my hand to get the time display to show on my tracker. With my new Inspire HR that doesn't seem to work and I can't find a setting for it. I have to touch the tracker with my other hand. Is there any way on the Inspire HR to accomplish that?
1 BEST ANSWER
Accepted Solutions
Ah, found the Setting and now it works just fine!
6 REPLIES 6
I find I have to give it the "correct" movement to wake up the display. Quite a slow twist of the wrist. My guess is that they make it like that so as not to be too sensitive.
Thanks! That doesn't seem to work for me, though. I'll have to practice! 🙂
Same question.....what setting did you use???
I pressed and held the button.The Settings appeared, which were battery life, "screen wakeup", and Notifications. Screen wakeup toggles off and on. Once I got it turned to On the clock face began showing up when I raised and turned my wrist.
You're a genius.....worked perfectly. Thank you so much!!! So many questions about this new gadget and wonder why I even buy them, but I do, LOL.
