06-22-2019 23:02
06-22-2019 23:02
On my Alta HR I could raise and twist my hand to get the time display to show on my tracker. With my new Inspire HR that doesn't seem to work and I can't find a setting for it. I have to touch the tracker with my other hand. Is there any way on the Inspire HR to accomplish that?
Best Answer06-24-2019 06:47
06-24-2019 06:47
Ah, found the Setting and now it works just fine!
Best Answer06-23-2019 05:55
06-23-2019 05:55
I find I have to give it the "correct" movement to wake up the display. Quite a slow twist of the wrist. My guess is that they make it like that so as not to be too sensitive.
Best Answer06-23-2019 07:12
06-23-2019 07:12
06-24-2019 06:47
Best Answer06-24-2019 09:34
06-24-2019 09:34
Same question.....what setting did you use???
Best Answer06-24-2019 11:03
06-24-2019 11:03
I pressed and held the button.The Settings appeared, which were battery life, "screen wakeup", and Notifications. Screen wakeup toggles off and on. Once I got it turned to On the clock face began showing up when I raised and turned my wrist.
06-24-2019 11:14
06-24-2019 11:14
You're a genius.....worked perfectly. Thank you so much!!! So many questions about this new gadget and wonder why I even buy them, but I do, LOL.
