05-01-2018 02:07
05-01-2018 02:07
For the 10 minute abs workout with the Versa there seems to be missing a side plank right. There is only the side plank left. Is this supposed to be like this? It seems very odd.Also the clock face doesn’t stay on during the workout which is extremely annoying. Anyway to fix this?
05-02-2018
08:35
07:18
05-02-2018
08:35
07:18
@JWillyD Welcome to the Fitbit Community! I hope you're doing well! You are right the right side plank isn't part of the routine and this is how the exercise was done (probably it would exceed the 10 minute mark). The same can be said about the screen turning off. Since you are doing exercises it isn't expected that you can see the screen. This is why the Versa vibrates to tell you the exercise is starting or ending and lights up to show the following exercise illustration. If you wish to see any of these options change please share them in our Feature suggestions board.
Let me know how it goes!
09-29-2018 10:53 - edited 11-11-2018 09:22
Thanks for the reply on this @AlvaroFitbit. I recently had to upgrade to an Ionic because my Blaze Fitbit screen broke. I was accustomed to doing the 10-minute ab workout on the Blaze regularly. That 10-minute workout included left and right side planks.
I think Fitbit has made an error in how it constructed the 10-minute ab workout for the newer Fitbits.
Is it possible for you or someone that works for Fitbit to actually confirm if this is an error or intentional?
Thanks!
11-11-2018 09:23
11-11-2018 09:23
Hello @AlvaroFitbit, I replied to you in September asking a question and have not heard back.
11-22-2018
08:09
07:17
11-22-2018
08:09
07:17
@jbot Thank you for the reply and sorry for the late reply. You are right only one side of the planks are showing. Not sure if this was intended but it is the way it is now. If you wish you can suggest for this to change in our Feature Suggestions board. The more votes an idea gets the more likely the developers will try to implement it.
Keep me posted!
11-26-2018 18:21
11-26-2018 18:21
If the side plank went over the 10 min mark then it shouldn’t be included at all if both sides aren’t covered. Take out the second set of mountain climbers or front plank.
12-04-2018
07:12
08:39
12-04-2018
07:12
08:39
@mill1703 Welcome! It's nice to have you on board! As I said, I am not sure why this was done the way it shows on the Versa but you can share this feedback on the Feature Suggestions boards. This way you will tell the developers about the corrections and changes you want to see on your Fitbit Versa.
Keep me posted!
12-21-2018 08:52
12-21-2018 08:52
I added this to the Feature Requests section. Please vote on it so the update is made. https://community.fitbit.com/t5/Feature-Suggestions/10-minute-abs-add-right-side-plank/idi-p/3131847...
