24 hour clock display will not revert back to 12 hour
I did the update on my Versa and it changed my display to 24 hours and I can't get it to revert back to the 12 hour display, does anyone know how to fix this?
2 REPLIES 2
Not 100% sure it will work, but you can try these instructions: https://youtu.be/_o78lsjKtJE
They're for Versa 2, but should be the same steps as for Versa. And, you'll want to choose 12-hour instead of 24-hour.
Thanks, I did all the normal things turns out it was in my clock face that I had to change it back.
