09-26-2019 18:09 - last edited on 09-27-2019 13:13 by LiliyaFitbit
I have gone into settings and changed the time to be shown as military time (24hr), and it says it’s updated, but my Fitbit is still showing normal time.
09-28-2019 13:29
09-28-2019 13:29
Hi, I installed this CF. My settings in Fitbit are 24 hrs and, in my case, km's. The Analog Stats CF shows only 12 hrs. I have tried many Third Party CF's and most of them do what you setup in the settings. This CF does not have a 12/24 hrs setting, so I'm convinced the problem is on the developer's side on not Fitbit one's. I would suggest to install a CF called Minimal Style. It's only 8,7 kB in size and highly customizable. On top of the screen you will see day and date, in the middle the time and on the bottom form left to righ: HR - Steps - Battery. Pressing on the steps cycles you through all the stats you want to know, like calories - distance - active minutes - and floors. Above all, it shows 24 hrs time and the distance in miles whenever that's your setting in Fitbit. This is also states in the description on this CF. Try it and you will love it. Use that, now on my Versa 2, already for a very long time without any problems. It's also by it's size very battery friendly. My last charge was 72 hours ago and my battery is now on 69%!!. Regards kuzibri
09-27-2019 13:10
09-27-2019 13:10
Welcome to the Fitbit Community, @Siplinger.
I appreciate your participation in the Forums and sharing that your device is showing normal time after you changed the time to be shown as military time. Thank you for letting me know that it shows as updated. I would like to confirm if you synced your device after you followed the steps to change to 24-hour clock. You can manually sync your device by following these steps.
Let me know how it goes.
09-27-2019 17:03
09-27-2019 17:03
It’s still showing 12Hr time and it’s also reading in meters too. I made sure I have it set to 24h and miles, and it’s synced. I emailed the person who made the specific clock face and he said it was a Fitbit problem not his.
09-27-2019 18:58
09-27-2019 18:58
Hi @Siplinger, thank you for your reply.
I appreciate your efforts and the additional details. Thank you for letting me know that you've been in touch with the developer of the clock face you're using. Please provide the name of the clock face for me to investigate further. I recommend restarting your device and switching to a Fitbit clock face to confirm the issue: How do I change the clock face on my Fitbit device?
Looking forward to your response.
09-28-2019 12:27 - last edited on 09-29-2019 12:03 by LiliyaFitbit
The name of the clock face is:
Analog stats for Versa by Alessandro Grazioli, thank you for your time and helping me with this issue.
Sincerely,
09-28-2019 13:29
09-28-2019 13:29
09-28-2019 14:09 - last edited on 09-29-2019 12:03 by LiliyaFitbit
Great thank you so much!
Sincerely,
09-28-2019 14:48 - edited 09-28-2019 18:06
Hi @Kelly Siplinger, did you install the Minimal Style CF already? If yes and you like it, would you be so kind to consider to mark my answer as an accepted solution or best answer as it is called now. Regards kuzibri
09-28-2019 22:11 - last edited on 09-29-2019 12:02 by LiliyaFitbit
Hi, I actually found another one I really like. I’m going to try it out first.
Sincerely,
09-29-2019 05:37
09-29-2019 05:37
Hi, what's the name of your CF? Regards kuzibri
09-29-2019 12:22
09-29-2019 12:22
It's great to see you around, @Siplinger @SunsetRunner.
@Siplinger I appreciate your efforts and the additional details. I am glad to hear the answer provided by @SunsetRunner helped you resolve your concern and you're trying now a new clock face.
@SunsetRunner thank you so much for taking the time to investigate this and provide the best answer regarding this matter. I really appreciate your efforts and your time.
Have you checked our Discussions board? There you can share your story, find some fitness tips, recipes and more! Give it a look!
09-30-2019 15:44
09-30-2019 15:44
Hi, just as a reminder: which CF are you using now. Regards kuzibri
