01-23-2019 03:45
01-23-2019 03:45
The alert on the watch appears to have stopped. It is switched on in the app. Where do I find it on the watch please
Best Answer01-23-2019 16:34 - edited 01-23-2019 16:48
Hi, swipe with your finger on your Versa from the bottom up and you will get the Today screen. In this screen you can activate up to 7 activities, one of which is the Steps per hour. Did you enable that on the Today screen? If not, go to it by swiping up from the bottom of your display and the Today screen appears after about 2 secs. Scroll down and go to settings and press it. Scroll down to steps per hour and if you did not enabled steps per hour, enable it and you're done. If you already have done that try restarting your Versa several times and see if this problem is solved.
Best Answer01-23-2019 16:53
01-23-2019 16:53
Um ... I actually have a versa and this does not work.
Best Answer01-23-2019 16:59
01-23-2019 16:59
Hi, you have a Versa you say and it does not work. What does not work?? See my post how to activate the steps per hour on your Versa.
