I understand there's a firmware update?  My Versa is currently synced, but still running 32-32-10.5 firmware
3 REPLIES 3
Hi, you probably mean this version: 32.33.1.19, could you check that by going to settings - device info - click that and on top of the screen you will see your current version. Am I right?
And yes there is a new Firmware version, e.g. 32.33.1.30. Whenever this update becomes avalaible for you, your Fitbit app will warn you about it with this message: "new update avalaible" in red.
You using the Versa?  Damm battery was holding a charge just fine, now, no more than a day...
Yes, I'm using the Versa. I assume you did the upgrade to version .30. If nothing has changed on your Versa except the new version, I would advice you call Customer Support about this battery issue.
