Accidentally deleted sleep setting on versa 2.
I've just got my versa 2 and was exploring the windows app. I clicked by sleep before realizing that means that I have deleted it from my settings. I want to track my sleep but does this mean I no longer have that function?
Is there any way to get it back please?
thanks.
Adele.
1 REPLY 1
Hello @adeleredfern
I’m hoping I understand your question correctly. If you are talking about your Sleep Tile in the online Fitbit Dashboard then tap dashboard on the upper right corner of your screen to enter the dashboard then tap the icon that looks like a rubric cube (see image) and you will see your sleep tile. Just tap it and it will return to the main Dashboard. Sync your Versa 2 to accept the changes.
If you are referring to the Fitbit App then open your Fitbit App then tap edit in the upper right corner (just under the envelope icon) now scroll down till you see the sleep tile then tap add. Now scroll back to the top and tap done. Sync you Versa 2 to accept the changes.
😃 I hope this answered and addressed your question properly. Please let me know. If not could you possibly offer me more clarification on which settings you think you might had deleted.
