01-19-2019 14:37
01-19-2019 14:37
I forgot my email adress & password,,i can’t use the fitbit versa tracker,,any one solve this issue???
Best Answer01-19-2019 15:36
01-19-2019 20:01
01-19-2019 20:01
@Razik32 do you get your weekly Fitbit reports on Monday? If so they are sent to the email that the account is registered with. Expanding the header will give you the address.
I see your posting from an account that was setup a few days ago, is this the same account that you have a question about? If so then go to your profile, your registered email will be at the top.
Removing the tracker from an account that you don't have access to would be a problem, but is not necessary to add your tracker to the account your now posting from and would be a second option if you don't mind losing your history.
