Accuracy issue in distance & sleeping
My versa is not give me accuracy in distance & sleeping time, when i walk 1 km it show me 0.60-0.7km
2 REPLIES 2
Answer depends on whether or not you are using connected-GPS to measure distance.
Also make sure your units are not confused.  1 km = .62 miles which is right at the % error you are seeing.
Are you using connected GPS? It should be very accurate the distance will use the GPS distance on your phone. If you're setting an excersie of walking for example but do not use GPS it will detect distance based on your steps which is only an approx measurement.
