01-27-2021
21:34
16:51
EdsonFitbit
01-27-2021
21:34
16:51
EdsonFitbit
I am using Versa 2. Got an app update couple of days ago. Since then the active minutes are not getting tracked properly. I usually clock over 150 active minutes on any given day and the same crosses 250 on my running days. After the update it is tracking erroneously. Yesterday it was below 50. and today also till now it is showing only 22...
Are others also facing similar issues? Any help here.
01-31-2021 16:49 - edited 02-01-2021 12:09
Thanks for visiting the Fitbit Community @Krishnan1974.
Thank you for the information provided.
Our team has recently released a new version of the Fitbit app (3.37.1). You can find instructions to update in this article.
Whether you continue experiencing the same problem, restart your Fitbit Versa 2 by following these steps.
For information about how your watch tracks your Active Zone Minutes, please visit this site.
If you have any question, please let us know.
01-31-2021 20:32
01-31-2021 20:32
Thanks for the reply. My App / watch is updated with the latest version 3.3.7.1.
The issue with tracking of active zone minutes started after the update. It was working fine before the update.
02-01-2021 12:25
02-01-2021 12:25
Thank you for the update @Krishnan1974.
The best way to get help for this problem is to chat with us online or give us a call. Please click here to get connected.
Please let us know if you have any questions.
02-01-2021 13:10
02-01-2021 13:10
I have the same problem on my Versa except that the active minutes appear and then disappear back to 0 after a second or two. Started after I did that last update. Is there a fix? JDM
02-02-2021 11:34
02-02-2021 11:34
Thank you for visiting the Fitbit Community @Jimdm.
I noticed that you've been in touch with Customer Support. I'm pretty sure they will do their best to provide a high level of support as soon as possible. Thank you for your patience while dealing with this situation.
Feel free to contact us at any time.
02-03-2021 20:39
02-03-2021 20:39
Thanks for the response. Sure will get connected. Just to share, today I did an high intense activity for about 85 minutes wherein I climbed 182 floors. The same has been captured by the tracker. But the active zone minutes is still ZERO.
It was working better before the update. Is this anyway I can downgrade and go back to the previous version?
02-04-2021 11:30
02-04-2021 11:30
Thank you for your response @Krishnan1974.
There is no option to downgrade to a previous Fitbit app version.
If you haven't done it already, you can set up your Fitbit Versa 2 as a replacement device:
See you around.
02-12-2021 01:30
02-12-2021 01:30
Yes I’m having the same issue. Registering intermittently.
02-12-2021 01:32
02-12-2021 01:32
Same issue here. So annoying. It was working fine before the update
02-12-2021 01:49
02-12-2021 01:49
02-12-2021 07:12
02-12-2021 07:12
I am having the same issue since the update. This morning I did 40 minutes of cardio and fat burning with weights and it measured 5 minutes in the zone and the calorie count seems to be a lot less as well.
