07-09-2018 18:59
07-09-2018 18:59
My watch is showing 5,922 steps and it shows the same on the main board but on my challenges it’s only showing 1,735. I’ve already tried resetting it changing wrists, disconnecting it from the Bluetooth and nothing. Has anyone else had this problem?
07-09-2018 22:57
07-09-2018 22:57
The most common cause of challenge steps being lower than your dashboard steps is where some of those steps were not directly tracked by the fitbit. For example, steps that came from manually logged activities or from syncing with other apps do not count towards challenges.
A less likely cause is where you are in a different timezone than the challenge creator. The start times being offset can cause confusion.
07-09-2018 22:58
07-09-2018 22:58
You may just need to do a sync and then it might show up correct on your challenges.
ALAN | VAN,B.C. Canada Community Council Member
Versa, Charge, Charge HR, Ionic, Ace, Aria 2 scale, Flyer headphones - iOS
Click here Fitbit help for more solutions
07-09-2018 23:06
07-09-2018 23:06
@Ilmota1113 wrote:Has anyone else had this problem?
Here are some more people that have had this problem.
https://community.fitbit.com/t5/Versa/Dashboard-amp-Challenges-information-don-t-match/m-p/2655387
07-10-2018 00:03
07-10-2018 00:03
Thank you!
07-10-2018 00:04
07-10-2018 00:04
Thank you!
