04-15-2019 14:14
04-15-2019 14:14
I really want to get the Versa Lite but I'd like to be able to use a photo as the background of the clockface. I can't really find any info on this since the Versa Lite is fairly new. Does anyone know if this is possible? Thanks!
Best Answer04-15-2019 14:45
04-15-2019 14:45
Hi, unfortunately this is not possible yet, cause all the Clock Faces off the Versa do not work on the Lite version. just be patient.
Best Answer04-15-2019 14:46
04-15-2019 14:46
It is possible on the Versa, though? I'm still considering buying the Versa over the Lite.
Best Answer04-15-2019 14:49 - edited 04-15-2019 14:56
Yes this is possible on the Versa so go and get the Versa!! 😊
Best Answer04-14-2020 11:26
04-14-2020 11:26
You can because I did. I have a fitbit versa lite.
Go to clock faces
All clocks
In the search, type photographs
It will pull up a cat with a camera on it. Select it and it will need to download.
Once its downloaded, you long press the picture and it gives you the option to customize your clock face with your camera or recent pictures.
Best Answer04-14-2020 11:28
04-14-2020 11:28
Yeah i asked this a year ago and have had a custom photo on the watch ever since lol
