02-10-2019 10:45
02-10-2019 10:45
Versa wont charge after 8hrs docked. Have tried restart. I do see condensation in back panel windows. Any suggestions?
Best Answer02-10-2019 17:27
02-10-2019 17:27
Hi, did you dry your Versa after the swimming, cause the Versa is, although water resistant to 50 meters, not waterproof? Since you're seeing condensation, I would advice you to contact Customer Support about it, maybe they will have some suggestions for you.
02-10-2019 18:05
02-10-2019 18:05
Best Answer02-10-2019 18:05
02-10-2019 18:05
Thank you
