After firmware, notifications stopped working
I did the firmware updated today and everything is working great except for my notification still. When I have one come in it still isn't popping up or even showing up. I checked the fitbit app and it says that Notification service not running. A phone restart is required. I have restarted and turn my phone completely off and on with no luck. I have an S9 so I know that isn't the problem.
5 REPLIES 5
@Kitsune99 Probably the process is getting killed by the Android. Please make sure Fitbit mobile app is not being optimized by Android (Android settings>Battery>Optimization>Fitbit needs to be marked as not optimized). Also, make sure Always Connected and Keep Alive Widget in the Fitbit mobile app are on.
Marrrmaduke | Canada
Charge HR, Blaze, Charge 2, Charge 3, Inspire HR, Versa Lite, Versa SE, Aria
I have the app already on not optimize along with everything else you said and it still says no notifications are allowed. I have also made sure that my notifications on the watch is turned on also.
@Kitsune99 Actually it is a knows issue for Samsung. See for instance this thread. There are several solutions mentioned. Perhaps you could try them, for example this one:
Settings -> Device care -> Battery -> Settings -> Sleeping apps -> Add -> Make sure Fitbit is unchecked -> Add -> Restart phone
Did everything the link told me and it didn't help at all. It actually made it worse as I wasn't getting phone call notifications on the watch as I was before. I turned everything back the way it was and my phone notification came back.
I finally just contacted Fitbit Support about this after going through everything and saying it was all correct this is what I got back: “We appreciate your cooperation in working on this. We’re aware of this issue and working to identify a resolution as quickly as possible. Thanks for your patience while we work to get you back on track, and let us know if you have any other questions.”
So it’s basically a known problem and they just haven’t gotten to fixing it yet because they want to get updates done on firmware first I guess.
