05-31-2020 11:43
05-31-2020 11:43
Hi all ,
After last update 35.70.8.0 , Samsung S6 device is not get phone call notifications. Actually yesterday i did not have any issue like that , but when i noticed the update and done it , problem was started. I did to Factory&Reset many times , and remove device i bluetooth , and check all required permissons , also uninstall fitbit app and reinstall it , all of them it did not help to solve it. In addition i checked the previous topic that is related same issue and it did not help to solve my problem . Moreover , i checked the compability android versions and it look no problem with my
05-31-2020 11:44
05-31-2020 11:44
Could you help or assit me please ?
Regards
05-31-2020 14:42
05-31-2020 14:42
What update did you do @Grkn01 the Fitbit app, the Versa 2 firmware, or a phone update?
Have you checked that notifications are still on? Some fitbit app or phone updates have revoked permissions on my android phone and I had to setup notifications again
Logging out the in on the Fitbit app will also force you to setup and grant permissions for notifications.
Also check the android tips.
