12-20-2018 20:53 - edited 12-20-2018 20:56
Hello,
My Versa just updated to firmware 3.0. Under "Today", I no longer have the option to view my female health information. I can still see the tile in my Fitbit app. It's just not showing on my Versa anymore. It was there before the update. I restarted a few times in hopes that that would help but nope, it didn't. Is anyone else having this problem?
12-21-2018 11:54
12-21-2018 11:54
In the app go to the versa and click on apps and under my apps click on "Today" and see if there is an update. For me there wasn't but after i did that and re-sync'd my water option showed up.
12-31-2018 09:14
12-31-2018 09:14
I was just about to respond to this because I was having the same issue but I just figured it out. After the update the default option for "today" gets wiped. If you swipe up on your versa to view today, scroll down to click the settings button. From there you can check the box for "cycle track". Then lock your versa to save the settings. Swipe up again and you should see your female health! You can also rearrange if you would like it higher on the list by long pressing the female health and dragging up or down on the list. You can only have 7 options for tracking so choose what you feel suits you best! Hope this helps 🙂
03-22-2019 06:34
03-22-2019 06:34
Thank you for your post, I was having issue with seeing my Female Health on my Versa after last update, but your post and advice has sorted it.
03-23-2019 14:11
03-23-2019 14:11
Hello @Greeneyes73, thanks for joining the conversation, it's great to have you on board the Fitbit Community.
I appreciate you have let us know the troubleshooting steps provided on this thread were helpful to you. I'm very glad. In case you have some spare time, I would like to invite you to visit our Discussions board where you will find great tips and encouragement from other members and if there's anything else I can do for you, please keep me posted!
